2 Pages<12
miken
#11 Posted : Sunday, October 26, 2008 9:43:09 PM(UTC)
miken
If the air flow is actually lower during cooling then the fan motor is getting power on a lower speed, if you followed the wires back to the board unless there is a jumper between the heat and cooling terminals there is no way to supply power from both relays to the same speed , look again.
2 Pages<12
