There should be no adjustment necessar for a Maytag belt. Your motor mount needs to be freely-sliding. Under normal operating conditions, the "slack" in the belt will be taken up by the spring-loaded motor mount to accomplish what other manufacturers install a clutch to do.
What symptom(s) lead you to believe you need a belt adjustment on your washer?
