Tom Wardynski
#1 Posted : Monday, March 7, 2011 3:25:54 PM(UTC)
Tom Wardynski
Rank:: Member
Wash cycle fine , but at start of rinse cycle the bottom fills up with water and eventually leaks out door all over floor . When the cancel button is pushed , the pump will empty all the water ,so no blockage in the line . Seems that the pump is not being energized at rinse cycle . Does anybody have an answer ?
Applianceaid
#2 Posted : Tuesday, March 8, 2011 9:46:38 PM(UTC)
Applianceaid
From what you are saying the control has failed, you narrowed it down to the only thing left. Replace the board the relay is not energizing the water valve.
ApplianceRepairLesson.com
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
lg wm2277hs drain problem (Washer Repair)
by Spiderman70 7/30/2020 6:37:35 AM(UTC)
kitchen aid drain problem not all the time (Dishwasher Repair)
by tom setre 1/22/2019 8:34:59 AM(UTC)
Drain problem (Dishwasher Repair)
by CATAXMAN 5/22/2015 7:42:29 AM(UTC)
Neptune MAH7500 - drain problem (Washer Repair)
by matopruth 3/8/2014 8:35:04 AM(UTC)
Maytag Neptune MAH5500BWW drain problems (Washer Repair)
by Tyork1 11/29/2013 6:02:24 PM(UTC)
neutral drain problem (Washer Repair)
by Tim2020 8/16/2013 9:47:57 PM(UTC)
Washing machine drain problem (Washer Repair)
by jon_e 1/5/2013 11:30:20 AM(UTC)
by hollowayv 12/4/2012 8:09:39 AM(UTC)
Fridigaire front loader drain problems (Washer Repair)
by jesse.rizzo 11/11/2012 10:52:28 AM(UTC)
Maytag Neptune Drain Problem (Washer Repair)
by dhornman 8/22/2012 9:04:48 AM(UTC)
Dishwasher drain problem (Dishwasher Repair)
by hunterman 11/14/2011 7:56:54 AM(UTC)
by youngstown2 11/12/2011 7:11:48 AM(UTC)
spin and drain problem calypso (Washer Repair)
by jim806 6/27/2011 2:25:50 PM(UTC)
Intermittent fill/drain problem (Dishwasher Repair)
by nele 4/22/2011 5:59:37 AM(UTC)
