2 Pages12>
dmcleer
#1 Posted : Monday, October 8, 2007 5:17:59 AM(UTC)
dmcleer
The washer basin will not spin and drain water. The motor is spinning and the gearbox output is also spinning. There is a silver disc/wheel that spins and gets very hot. I notice the brake seems to be engaging/disengaging, but not sure why basket won't turn.
#2 Posted : Tuesday, October 9, 2007 1:14:41 AM(UTC)
You probably have something stuck in the tub, just shine a lite in there to check.If so, you will need to pull spin basket. Also the plastic filter under basket sometimes drags on the bottom of the tub.
If everything ok there, you probably have dragging brake shoes. Pull motor and t and turn tranny coupler clock wise. If hard to turn this confirms bad brake shoes.Remove tranny.
Pry down spin tube enough to clear brake shoes from housing and remove and replace. Just call Appliancepartspros for part #.
dmcleer
#3 Posted : Tuesday, October 9, 2007 5:44:12 PM(UTC)
dmcleer
Thanks for the info. Where/how exactly do I pull the basket to check if something is stuck in it?
#4 Posted : Wednesday, October 10, 2007 12:54:13 AM(UTC)
Pull outer cover from washer,remove plastic tub top and agitator. you will see a aluminum nut. It is a right hand thread, just turn counterclockwise with a short pipe wrench. I put the nut on half way and pound on it to break loose the basket.
dmcleer
#5 Posted : Thursday, October 11, 2007 5:47:51 PM(UTC)
dmcleer
okay, I pulled the spin basket, and found the shaft spins just fine, without the basket on it. Also i didn't have to pull the aluminum nut off the nasket just came off pretty easily. The problem as I see it, the shaft spins, but the basket slips. The shaft spins and the basket sits still. As a temp fix I wrapped the shaft with some duct tape, and it is working for now, but it won't last forever. Does the aluminum nut close the split collar around the shaft, causing the required friction to turn the basket?
#6 Posted : Friday, October 12, 2007 12:24:37 AM(UTC)
You probably need a new drive block that mounts on top of the spin tube. Also, did you check the filter under the spin basket. Sometimes they break and jam under the spin basket and hit the tub bottom.
dmcleer
#7 Posted : Friday, October 12, 2007 4:05:59 AM(UTC)
dmcleer
What does the spin block look like? The filter was kind of nasty and falling apart in places, but I don't believe that is the problem. I notice two tines sticking off the top of the drive shaft, do they do anything?
#8 Posted : Friday, October 12, 2007 5:16:42 AM(UTC)
The drive block is slid over the end of the spin tube that drives the spin basket and the nut screws onto. There are slots in this drive block that slip into these spin tube spines and prevent it from spinning. You will probably need a new drive block.
oldman60
#9 Posted : Friday, October 12, 2007 4:48:09 PM(UTC)
oldman60
hi guys!
i got the almost exact same symptoms with my whirlpool.drivin me nuts!i still dont fathom how the clutch works!here's a pic of parts.why does the yelow nylon brake release have that funny little tang and slot?what is that little hook shaped wire for?somethimes when i put it all together it spins(if i try agitate first) and when i release the lid switch it stops on a dime!!then if i hit switch again motor goes and clutch drum spins but nuthin happens with tub!would it stop on a dime if tub drive block was shot?:D
oldman60 attached the following image(s):
dmcleer
#10 Posted : Saturday, October 13, 2007 9:42:46 AM(UTC)
dmcleer
where do i get a drive block?, and how do i get the nut off. I can't get any leverage. I can't get it to budge at all.
Guest (6)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
2 Pages12>
