zebra47cb
#1 Posted : Thursday, February 24, 2011 2:53:01 PM(UTC)
zebra47cb
This dryer was running fine, I opened the door checked to see if things were dry, closed the door and it would not start. I have checked the door switch, thermostats and thermal fuse. All checked OK. With power to the dryer the timer sounded as if it were running. I tried to check the start switch but didn't know what terminals to ckeck. I got a reply on this site and a wiring diagram and was a little confused as the R1 and R2 and CT1 terminals didnt match the diagram on the switch housing. So I tested the two blue wire terminals(the ones I though were the R1 and R2 terminals) and got a 0 ohm reading. Should I get CT1 terminal and any other terminals, if so which ones ? What else could be causing my problems?
dp310
#2 Posted : Thursday, February 24, 2011 3:07:13 PM(UTC)
dp310
did you check the door swich with the dryer door closed? the arm on the switch may have broken not allowing the door to engage the switch.
zebra47cb
#3 Posted : Thursday, February 24, 2011 4:01:59 PM(UTC)
zebra47cb
I checked that in the closed position and it checked fine.
Guest (4)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 5/3/2015 6:59:24 AM(UTC)
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 8/19/2014 6:07:34 PM(UTC)
by jdbell1114 3/17/2014 5:58:20 PM(UTC)
by emontoute 8/4/2013 10:01:22 AM(UTC)
by Turtleman1961 1/18/2013 5:52:20 PM(UTC)
Whirlpool Dryer won't start (Dryer Repair)
by adsch 6/26/2012 7:55:27 PM(UTC)
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 1/14/2012 11:52:35 AM(UTC)
by gunworks 12/14/2011 6:47:15 PM(UTC)
by patarnotte@comcast.net 12/6/2011 1:57:13 PM(UTC)
Whirlpool Dryer won't start, but hums (Dryer Repair)
by gmreeves2 12/1/2011 8:16:57 PM(UTC)
by JWCL 11/29/2011 6:43:51 AM(UTC)
by moonie777 5/13/2011 8:59:04 AM(UTC)
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 12/24/2010 1:06:56 PM(UTC)
by hol99 12/15/2010 8:39:33 PM(UTC)
