3 Pages<123>
John Lamb
#11 Posted : Friday, September 26, 2008 4:02:27 AM(UTC)
John Lamb
Nat,
I thought it was the CCU & I replaced it & it did not change a thing So do you have any suggestions on what I might look at next..?:confused:
John Lamb
#12 Posted : Friday, September 26, 2008 5:43:20 AM(UTC)
John Lamb
Nat,
I replaced the CCU & nothing changed do you have any suggestions on what I might try next..:confused:
Thanks,
John
libertyappl
#13 Posted : Friday, September 26, 2008 5:44:54 AM(UTC)
libertyappl
John,
Test the water valve make sure it's good, don't know why I didn't think of that before....Let me know
Nat
ps. did you get the rest of the model number?
John Lamb
#14 Posted : Friday, September 26, 2008 5:47:53 AM(UTC)
John Lamb
yes I have all the model number WFW8300SW01 where is the water valve located..? where the water comes in..?
libertyappl
#15 Posted : Friday, September 26, 2008 5:49:52 AM(UTC)
libertyappl
Yes, where the water comes in.....you will have to remove the top again to get to it.
Nat
libertyappl
#16 Posted : Friday, September 26, 2008 5:55:07 AM(UTC)
libertyappl
This may help also.
Nat
File Attachment(s):
WFW8300SW01 wiring.pdf (179kb) downloaded 9 time(s).
John Lamb
#17 Posted : Friday, September 26, 2008 5:57:22 AM(UTC)
John Lamb
Like where the 2 hose connect is that also called the water flow meter.. do you think it could be teh key pad unit..?
John Lamb
#18 Posted : Friday, September 26, 2008 6:01:02 AM(UTC)
John Lamb
Nat,
I just looked at that latest wiring PDF you sent me. I will try some of those test this weekend & see if I get a Error code..
Thanks,
John
libertyappl
#19 Posted : Friday, September 26, 2008 6:10:51 AM(UTC)
libertyappl
Keep me posted.
I will be gone a lot Sat. & Sun., I have to go take my continuing education classes to renew my real estate license. But will check as often as I can and some of the other may jump in as well.
Nat
John Lamb
#20 Posted : Wednesday, October 1, 2008 4:05:36 AM(UTC)
John Lamb
Nat.
I worked on the washer last night & ran the Diagnostic test that it talked about in manual you sent me. I never did get a error code., but after I did run it the light was blinking at rinse/spin when Looked it up it said door lock problem.. Ok I knew that So I have replaced the door switch I have put in a new ccu so what do you think I need to do now.
Thanks for the help
whirlpool washer will not do anything but buzz and fill up. (Washer Repair)
by KayleeMaesmommy 4/25/2012 11:52:22 AM(UTC)
3 Pages<123>
