runningspike
#1 Posted : Sunday, February 20, 2011 3:03:46 PM(UTC)
runningspike
I believe I need to replace the water inlet valve. Is that correct and is there something else I should replace? Thanks!
#2 Posted : Monday, February 21, 2011 2:47:26 AM(UTC)
Replacement parts for KENMORE 11026812690 | AppliancePartsPros.com
Could be the water level switch.
Part number: AP4567828
May just be the pressure hose
Part number: AP3098609
Click on the pictures for more info.
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
Note: That you may be able to stop it by blowing into then tubing and it may still be no good as it needs too much pressure to activate the switch.
So if the tubing is OK replace the switch.
Note: I am assuming that you can stop the water flow by unplugging or turning off the unit.
If the only way to stop it is to shut off the taps your water valve is shot.
runningspike
#3 Posted : Monday, February 21, 2011 4:21:55 AM(UTC)
runningspike
Thanks Denman. Tried your recommendations and it turns out it is the valve as I am unable to shut the water off without shutting the valve. Thanks again!
Washer overfilling (Washer Repair)
by 3DPiper 11/8/2016 10:23:12 AM(UTC)
GE Washer Overfilling (Washer Repair)
by Liriodendron 3/12/2015 11:48:35 AM(UTC)
washer overfilling (Washer Repair)
by Doug51 9/8/2013 9:44:36 PM(UTC)
GE Washer overfilling (Washer Repair)
by vman1 1/2/2013 10:39:21 AM(UTC)
Washer overfilling and not automatically spinning (Washer Repair)
by stubby0011 8/11/2010 7:50:33 AM(UTC)
help with GE washer overfilling (Washer Repair)
by doomee 12/15/2009 12:46:50 PM(UTC)
Belarus scotte 10/7/2009 7:00:39 PM(UTC)
by jtowntbo5@yahoo.com 1/8/2009 7:24:04 AM(UTC)
dishwasher overfilling (Dishwasher Repair)
by Vulcan 12/14/2008 5:06:33 PM(UTC)
by xmasbaby63 8/16/2008 2:22:47 PM(UTC)
