When I pull out the knob to turn the water on, it just drips in. It worked fine last night and now it's not working. What could be wrong? It just makes a buzzing noise. It spins fine.
TIA.
Turn off your water supply and disconnect your hoses, look inside see if there is any debris on your screens, if so use a qtip or old tooth brush to clean them, being careful not to puncture the screens. Nat
Originally Posted by: libertyappl  Turn off your water supply and disconnect your hoses, look inside see if there is any debris on your screens, if so use a qtip or old tooth brush to clean them, being careful not to puncture the screens. Nat Thanks Nat. That's what I'll do. I did figure out that it's just the cold water that's not coming through.
More than likely it's clogged. Nat
It's not clogged. The cold water comes through the hose just fine. I read another post where you spoke of a valve. What valve?
If your supply is good to the mixing valve and nothing will come out, most likely the buzzing you hear is it "trying " to energize.
I don't see a model number listed on this post,otherwise I would try to find the part number for you, most maytags are on a sticker in the back of the unit, if you lean over the console where the timer is
