deelaneford
#1 Posted : Tuesday, September 23, 2008 4:40:23 AM(UTC)
deelaneford
When I pull out the knob to turn the water on, it just drips in. It worked fine last night and now it's not working. What could be wrong? It just makes a buzzing noise. It spins fine.
TIA.
libertyappl
#2 Posted : Tuesday, September 23, 2008 11:55:42 AM(UTC)
libertyappl
Turn off your water supply and disconnect your hoses, look inside see if there is any debris on your screens, if so use a qtip or old tooth brush to clean them, being careful not to puncture the screens.
Nat
deelaneford
#3 Posted : Wednesday, September 24, 2008 4:13:53 PM(UTC)
deelaneford
Nat
Thanks Nat. That's what I'll do. I did figure out that it's just the cold water that's not coming through.
libertyappl
#4 Posted : Wednesday, September 24, 2008 4:31:42 PM(UTC)
libertyappl
More than likely it's clogged.
Nat
deelaneford
#5 Posted : Sunday, September 28, 2008 10:13:06 AM(UTC)
deelaneford
It's not clogged. The cold water comes through the hose just fine. I read another post where you spoke of a valve. What valve?
Zanshin
#6 Posted : Sunday, September 28, 2008 10:29:05 AM(UTC)
Zanshin
If your supply is good to the mixing valve and nothing will come out, most likely the buzzing you hear is it "trying " to energize.
I don't see a model number listed on this post,otherwise I would try to find the part number for you, most maytags are on a sticker in the back of the unit, if you lean over the console where the timer is
