chef_m
#1 Posted : Saturday, February 19, 2011 12:03:52 PM(UTC)
chef_m
Hi. I'm trying to fix a front load washer for a friend of mine who is sick. Symptom: will fill but not agitate. Error code: following Tech Sheet, get error E5E -- communication; "check wiring between control board and speed control".
Problem: can't see the speed control (aka motor control?) on diagrams -- it's pictured in an insert, but where in the cabinet is it? Put differently, I understand that I'll check the harness connecting at the main control board, but I was hoping to know in advance where that harness will go -- front, back, up, down, left, right?
Can anyone help? Thanks in advance.
#2 Posted : Sunday, February 20, 2011 5:30:53 AM(UTC)
chef_m
#3 Posted : Sunday, February 20, 2011 8:49:45 AM(UTC)
chef_m
That's awesome! Thank you.
chef_m
#4 Posted : Sunday, February 20, 2011 5:42:10 PM(UTC)
chef_m
The service manual was exactly what I needed; it turned out to be a loose connection from the wire harness <--> J2 on the speed control unit. It doesn't use clips or a firm connector -- it just slides over contacts embedded in the circuit board. The harness had just worked it's way off of some of the contacts.
And thanks to having the manual, that point was the one I was guessing it was -- and it was the easiest one to get to as well. Thanks again.
S.Nielson
#5 Posted : Sunday, February 20, 2011 6:43:32 PM(UTC)
S.Nielson
I'm having about the same problem. Click on "find parts" on this site and type in your model number. It should be part #1 towards the top right behind the controls.Hope this helps. S.Nielson
S.Nielson
#6 Posted : Sunday, February 20, 2011 6:49:34 PM(UTC)
S.Nielson
I'm having the same problem.Click on "Find Parts" on this site.Type in your model number. It should be #1 right behind the control panel.Hope this helps. S.Nielson
