jamesamc
#1 Posted : Sunday, July 22, 2007 10:37:35 AM(UTC)
jamesamc
Washer fills to proper level but won't agitate, timer continues thru cycle until the drain and rinse cycle and then it works fine and finishes the cycle. During the agitate phase there is a slight buzzing sound with the control panel off, otherwise it makes no sounds or movements until the rinse cycle starts. Is this water level switch or timer problem? Thanks
Adam / APP Team
#2 Posted : Tuesday, July 24, 2007 1:42:09 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear Jamesac,
If your getting a slight buzzing noise coming from the TIMER in that cycle most likely it is the problem.
Maytag Washer fills but won't agitate, spin, or drain (Washer Repair)
by Liv2bhappy 12/8/2014 5:36:46 AM(UTC)
Washer fills but won't agitate (Washer Repair)
by Kdw111 11/21/2012 1:52:55 AM(UTC)
washer fills but won't agitate, drain or spin (Washer Repair)
by gtanse 5/12/2012 3:59:46 PM(UTC)
by pansie 1/14/2012 3:13:53 PM(UTC)
Washer fills but won't agitate or spin (Washer Repair)
by garystarh 9/29/2011 9:12:27 AM(UTC)
by garystarh 9/29/2011 9:08:07 AM(UTC)
Washer fills but won't agitate or drain (Washer Repair)
by Desirae 8/29/2008 11:42:07 AM(UTC)
