Kunami61
#1 Posted : Sunday, September 21, 2008 7:38:33 AM(UTC)
Kunami61
I need to replace a water valve and don't know where to start. Any help where to begin?
libertyappl
#2 Posted : Sunday, September 21, 2008 8:02:32 AM(UTC)
libertyappl
Raise the top, 2 clips about 2 inches in from the corners(use a putty knife), undo the clips on the case, remove the outer case, locate the valve, part #285805, replace and reverse the process making sure to get the case back on securely.
Nat
Kunami61
#3 Posted : Sunday, September 21, 2008 8:36:21 AM(UTC)
Kunami61
Thanks for the headstart, I just replaced it and will give it a try. I would recommend using pliers instead of putty knife to pop the clips. :)
Thanks LibertyApp!
Ge Washer water valve (Washer Repair)
by LeeL 1/3/2012 5:15:37 PM(UTC)
Maytag Washer Water Valve (Washer Repair)
by barnesed 3/2/2011 5:55:50 AM(UTC)
GE Dishwasher Water Valve Replacement (Dishwasher Repair)
by mikegundy 1/29/2011 8:37:14 AM(UTC)
washer water valve (Washer Repair)
by angie122364 11/2/2010 2:32:23 PM(UTC)
Frigidaire Affinity Washer Water Valve Harness Locking Plugs (Washer Repair)
by rickden 7/22/2009 4:34:40 PM(UTC)
Maytag washer water valve replacement (Washer Repair)
by catrinka55 5/1/2009 8:48:40 AM(UTC)
