cyndyh
#1 Posted : Tuesday, March 25, 2008 11:21:40 AM(UTC)
cyndyh
I bought a new upper spray arm. When I attach it to the old upper spray arm bracket the arm hits the upper rack. Is the post on the upper bracket supposed to be slanted?:confused:
meesh
#2 Posted : Wednesday, September 10, 2008 4:09:32 PM(UTC)
meesh
I'm having the same issue. I've checked the diagram to make sure I'm not missing a piece and everything is correct. The spray arm hits the right side of the upper rack where it is deeper (lower) than the left side.
Thanks for the help.
meesh
#3 Posted : Friday, September 19, 2008 10:45:04 AM(UTC)
meesh
Anyone have any ideas why the spray arm is hitting the bottom right side of the upper rack?
libertyappl
#4 Posted : Friday, September 19, 2008 10:55:19 AM(UTC)
libertyappl
No the bracket isn't supposed to slanted. Check the tiered bracket which the arm connects to it could be broken. Also check the arm to make sure that nothing is lodged inside making it off balance.
Nat
Guest (5)
