Amatuer2
#1 Posted : Wednesday, September 10, 2008 4:38:07 PM(UTC)
Amatuer2
whirlpool dishwasher model GU980SCGB0 won't drain or fill. After you've pushed the buttons , it waits that amount of time that it would fill , then starts the wash cycle or drain. but it didn't really fill and doesn't drain (the water the still in the bottom)
streetlighter
#2 Posted : Sunday, September 14, 2008 12:23:16 PM(UTC)
streetlighter
Hi
Bail the water out with a cup and a sponge, then try again.
Keep an eye on it because if its blocked up in the sensor pots it may over fill and flood.
libertyappl
#3 Posted : Sunday, September 14, 2008 1:21:05 PM(UTC)
libertyappl
Check your pump for any obstructions. If none found test the water valve. Post your results
nat
Marvin Goretski
#4 Posted : Thursday, September 18, 2008 1:23:01 PM(UTC)
Marvin Goretski
dishwasher will not fill it heats but no water
Maevin
libertyappl
#5 Posted : Thursday, September 18, 2008 1:28:05 PM(UTC)
libertyappl
Marvin,
That's probably your inlet valve. If you need the part number post your model number.
Nat
Guest (4)
