rmarmion
#1 Posted : Tuesday, February 8, 2011 8:00:48 AM(UTC)
rmarmion
Put in new cold control and defrost control. Unit does not turn on at all. Even after 1 hour. Put old defrost control back and unit turns on right away.
#2 Posted : Tuesday, February 8, 2011 10:57:42 AM(UTC)
Your new defrost timer was probably in defrost when you put it in. If you turn the control knob till it clicks, that verifies it was in defrost.
Pull your freezer back panel and check for frost buildup, post results.
rmarmion
#3 Posted : Wednesday, February 9, 2011 5:10:05 AM(UTC)
rmarmion
No knob on defrost timer, just the time whole shows thru refrig fresh food compartment on GE Hotpoint Automatic defrost. Also no frost on back. How long should it stay in defrost anyway? The freesh food is cooling to about 38 and freezer to 10 degrees F but shuts off till it reaches about 35.
As I said in first post I've purchased a cold temp control and it works with refrig, but when I put in defrost control, it doesn't fire up until I put old one back.
#4 Posted : Wednesday, February 9, 2011 10:04:24 AM(UTC)
The defrost timer AP2061695 is white plastic with a circular hole. Stick a flat bladed screw diver in there and turn clockwise till it clicks, then it will be out of defrost.
If the fridg runs a lot and the freezer only gets down to 10 degrees, you either have clogged condenser coils, a bad condenser motor, or system problems/ refrigerant leak.
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Fridge not cooling enough, but Freezer is fine (Refrigerator & Freezer Repair)
by corriganama 8/19/2019 10:48:58 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Refridgerator/Freezer not cooling enough (Refrigerator & Freezer Repair)
by blbrchnk 12/15/2016 5:08:53 AM(UTC)
GE GSS25SGPA refrigerator not cooling enough (Refrigerator & Freezer Repair)
by jhinson 9/14/2016 5:50:34 AM(UTC)
Fridge not cooling enough (Refrigerator & Freezer Repair)
by izook 4/20/2016 10:05:53 PM(UTC)
Refrigerator is not cooling enough (Refrigerator & Freezer Repair)
by anil_rathore 4/18/2016 10:38:10 AM(UTC)
FRIGIDAIRE not cooling enough (Refrigerator & Freezer Repair)
by SHOOTER468 9/22/2014 6:29:18 AM(UTC)
lg fridge not cooling enough in freezer compartment (Refrigerator & Freezer Repair)
by gregaguilar 7/21/2014 10:01:50 AM(UTC)
JENN-AIR Side-by-side fridge par not cooling enough (Refrigerator & Freezer Repair)
by FJ60 6/23/2014 4:03:05 PM(UTC)
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 3/27/2014 4:23:35 PM(UTC)
Kenmore freezer and refrigerator not cooling enough (Refrigerator & Freezer Repair)
by vikasintl 8/27/2013 12:54:20 PM(UTC)
Amana SXD22S2W Not cooling enough. Ice buildup on evaporator at defrost thermostat (Refrigerator & Freezer Repair)
by DawgFan 7/7/2012 10:21:14 AM(UTC)
GE refrigerator not cooling enough (Refrigerator & Freezer Repair)
by rich2k 9/3/2011 3:59:52 PM(UTC)
GE Freezer and fridge not cooling enough (Refrigerator & Freezer Repair)
by terrynow 9/22/2010 12:22:33 PM(UTC)
