tstone
#1 Posted : Wednesday, September 17, 2008 9:04:18 AM(UTC)
tstone
my electronic display shows the time and allows me to turn the oven on but neither element heats up in bake or broil mode. I opened it up, all the wiring looks intact, I can't find any fuses. Do I need to replace the electronic control panel/
libertyappl
#2 Posted : Wednesday, September 17, 2008 2:34:52 PM(UTC)
libertyappl
Is this a single or double oven? The wiring diagram has both.
Nat
tstone
#3 Posted : Wednesday, September 17, 2008 8:20:47 PM(UTC)
tstone
it is a single oven
libertyappl
#4 Posted : Wednesday, September 17, 2008 8:28:57 PM(UTC)
libertyappl
Ok, I looked at the wiring diagram.....and I don't think it's your control board.
Lets see if we can reset your unit, go to your breaker box throw the breaker all the way off and wait a few seconds then turn it back on. Try the oven.
Let me know what it does.
Nat
tstone
#5 Posted : Thursday, September 18, 2008 5:38:26 AM(UTC)
tstone
I switched the breaker off and waited a couple minutes and it is still doing the same thing after I switched it back on. By the way thank you for responding to my question
libertyappl
#6 Posted : Thursday, September 18, 2008 7:35:04 AM(UTC)
libertyappl
check the Volts at the breaker make sure it's getting 220V, you may also need to also pull the oven and check the voltage there. If getting the correct voltage then I could be wrong and it be the control board.
nat
tstone
#7 Posted : Thursday, September 18, 2008 7:44:25 PM(UTC)
tstone
The problem started directly after using the self cleaning mode. There is a switch directly on top of the oven box that interacts somehow with the self cleaning door lock. Could this be where a problem of this type could occur?
libertyappl
#8 Posted : Thursday, September 18, 2008 7:49:44 PM(UTC)
libertyappl
Very possible there have been several issues with using self clean and the door latches.
File Attachment(s):
wpl self clean.pdf (93kb) downloaded 5 time(s).
Guest (4)
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
Vintage Wall Oven SIZES (General Talk)
by sabfre 12/21/2023 8:52:31 AM(UTC)
GE Monogram Electric Wall Oven Model No. Z EK938SM1SS (Oven Repair (including Ranges and Cooktops))
by Govtman 11/14/2023 7:24:46 PM(UTC)
Kenmoore wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 6/23/2023 1:46:47 PM(UTC)
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 6/4/2023 8:04:00 PM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
Gaffers and Sattler wall oven 1970-1980 models (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2023 2:45:52 PM(UTC)
Determining voltage for 1960s GE-J-720 wall oven install (Oven Repair (including Ranges and Cooktops))
by Austo1989 2/22/2023 4:33:49 PM(UTC)
Jenn air double wall oven control panel problems (Oven Repair (including Ranges and Cooktops))
by Guest 2/2/2023 3:45:53 AM(UTC)
Old GE Double Wall Oven - Top isn't working (Oven Repair (including Ranges and Cooktops))
by Doubletheoven 11/25/2022 5:19:46 AM(UTC)
Maytag wall oven door won't unlock (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:44:59 AM(UTC)
