Will not dicharge soapy water in order to rinse.The only way it will work is if I turn knob to spin and complete spin cycle, then back to rinse then it will fill up with fresh water.
Thanks, Novice
Sounds like a bad timer. You can click on your model # above to order it.
Thanks for the info. I'll try it.
Novice
