kentharper
#1 Posted : Wednesday, February 2, 2011 12:28:58 PM(UTC)
kentharper
the cycle control was rotated while pulled out by mistake.Now no water will enter machine. Replaced the water level switch and water inlet valve but no help. All I can get is a low hum from machine for 10 to 15 seconds before stopping. drain and spin cycles ok but no water fill or rinse in any position of control. help is appreciated.
magician59
#2 Posted : Wednesday, February 2, 2011 1:57:51 PM(UTC)
magician59
Check to make shre there is no obstruction in the water hoses. Make sure the water is turned on (This comes from experience, so don't go thinking I'm being facetious here).
There should have been free play in the timer shaft to prevent damage; but it is possible that your timer is at fault.
kentharper
#3 Posted : Thursday, February 3, 2011 7:31:08 AM(UTC)
kentharper
thanks for reply; checked water hoses . problem occurred after successful completion of initial load of wash;got in a hurry and spun dial when timer knob pulled out.
kentharper
#4 Posted : Thursday, February 3, 2011 8:34:05 AM(UTC)
kentharper
ordered new timer will keep posted
magician59
#5 Posted : Thursday, February 3, 2011 8:37:51 AM(UTC)
magician59
Hope that does it...Let us know.
kentharper
#6 Posted : Thursday, February 3, 2011 11:20:22 AM(UTC)
kentharper
any secret on removal of knob from timer switch? thanks
magician59
#7 Posted : Thursday, February 3, 2011 12:22:40 PM(UTC)
magician59
Open the control panel. In the center of the timer you'll see a plastic peg. Pill it out about 3/4" and the knob will release from the front. The dial just pulls straight off.
kentharper
#8 Posted : Friday, February 4, 2011 8:27:19 AM(UTC)
kentharper
thanks for followup
kentharper
#9 Posted : Thursday, February 10, 2011 8:45:32 AM(UTC)
kentharper
Bingo! The timer was the problem. Thanks again for the3 help!
magician59
#10 Posted : Thursday, February 10, 2011 9:00:21 AM(UTC)
magician59
Glad you got it. You saved yourself a ton of money!
Guest (6)
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
