4 Pages<1234>
libertyappl
#21 Posted : Monday, September 15, 2008 7:15:05 PM(UTC)
libertyappl
I'm trying to do a cross reference over to the manufacturer (Whirlpool)for a wiring diagram. the 628519 is the old part number the newer version is 8201515.
nat
duramax100
#22 Posted : Monday, September 15, 2008 7:21:24 PM(UTC)
duramax100
nat
when i put in either number the same one comes up if you enlarge the picture the part # is 628519 oh and the new i m came with the on and off bar my old one didnt have that
john
libertyappl
#23 Posted : Monday, September 15, 2008 7:29:45 PM(UTC)
libertyappl
yes, they just changed one thing on the 1st version and gave it a whole new number with a better piece. As a warranty company we aren't supposed to use the old number. That's all.
duramax100
#24 Posted : Monday, September 15, 2008 7:33:12 PM(UTC)
duramax100
nat
could it have burned out the circuit boared
john
libertyappl
#25 Posted : Monday, September 15, 2008 7:44:32 PM(UTC)
libertyappl
John,
I finially found the one I've been looking for. This is a service tech sheet on the optics for the ice maker.
Sorry it took so long, they post a lot of stuff for us to use.
Nat
File Attachment(s):
IM optics.pdf (50kb) downloaded 5 time(s).
duramax100
#26 Posted : Monday, September 15, 2008 7:56:41 PM(UTC)
duramax100
nat
its ok i will take a look at it
thanks
john
duramax100
#27 Posted : Monday, September 15, 2008 8:17:31 PM(UTC)
duramax100
nat
im not sure how to jump the wires but when i open the door the led flashes twice and when i close the little door on the left to line up the optics its solid red and if i depress the freezer light switch to turn the freezer light off then the led light goes off
john
duramax100
#28 Posted : Monday, September 15, 2008 8:45:54 PM(UTC)
duramax100
nat
i think im going to replace the the ice level control part # 4389102 what do you think
john
libertyappl
#29 Posted : Tuesday, September 16, 2008 6:52:21 AM(UTC)
libertyappl
From what you told me you probably should, appears you had IM problems & emitter issues too.
Nat
duramax100
#30 Posted : Tuesday, September 16, 2008 5:30:00 PM(UTC)
duramax100
nat
had the wrong thermostat in it oops now its working fine plenty of ice i just need to adjust the size on the little screw thanks a million you do a great service for us all again thank you
john
ps im buying all my parts from you guys from now on you got the best prices and great delivery time
Guest (11)
4 Pages<1234>
