Davidprn
#1 Posted : Sunday, September 14, 2008 8:07:19 AM(UTC)
Davidprn
Washer making squealing sound while burning though belt is this a brake problem or transmission. The unit belt and pump was changed a few weeks ago and the washer performed well . Now the problem is back Do you have any idea?
libertyappl
#2 Posted : Sunday, September 14, 2008 8:29:51 AM(UTC)
libertyappl
If the tension on the belt that was installed recently was to tight it probably caused more problems. Did you have a tech come out or do it yourself?
Nat
Davidprn
#3 Posted : Monday, September 15, 2008 3:50:34 AM(UTC)
Davidprn
NAt,
Are you saying the belt tension is the reason why the unit worked for weeks and then the pulley tension caused the belt to break? What about the break or the transmission? After the belt was changed I noitce the tub would not turn. I had to turn it counter clock wise to free it and then the motor was able to turn the tub freely.
libertyappl
#4 Posted : Monday, September 15, 2008 7:06:33 AM(UTC)
libertyappl
No, I'm just saying that if the belt is put on and the tension to tight it can cause more problems. It's possilbe that the brake is grabbing too if you can get it going by hand. You may want to check it and see if that's the case.
Nat
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
Belarus gefixin 5/20/2024 2:01:39 PM(UTC)
