2 Pages12>
Montana_Pete
#1 Posted : Friday, September 12, 2008 6:00:02 PM(UTC)
Montana_Pete
I need some serious help with this new GE washer. GE washer will no longer spin or agitate. Will fill and drain ok. But no motor action.
#1 I checked inline motor fuse it looked ok. But direct wired it anyway :)
#2 Motor LED flashes constantly 1sec on 1sec off
What sensor might no be letting the motor start?
What should I check next?
Washing backing up here in Montana :(
libertyappl
#2 Posted : Friday, September 12, 2008 8:19:24 PM(UTC)
libertyappl
I can't pull up the model number you have posted, but start by checking the lid switch and the belt. and double check the model number please.
Nat
Montana_Pete
#3 Posted : Saturday, September 13, 2008 11:26:37 AM(UTC)
Montana_Pete
http://products.geapplia...SE5240GWW&SITEID=GEA
Yes belt is perfect and lid switch is magnetic and makes a little clicking sound when I open and close it.. Machine is just over a year old....
Motor LED binks on / off every one second constant.
Water fills and drains but it just won't activate the motor.
Should I cut lid wires and connect to be sure?
libertyappl
#4 Posted : Saturday, September 13, 2008 11:37:55 AM(UTC)
libertyappl
Check the connections at the motor, and if you can test the motor. We had one of these about a month ago and it was the motor. I don't remember all the details of it will have to look it up.
Nat
Montana_Pete
#5 Posted : Saturday, September 13, 2008 9:08:49 PM(UTC)
Montana_Pete
I don't know how to test the motor.
LED is blinking 1 sec on 1 sec off contant.
Do you have a hot wire pin out for this thing?
#6 Posted : Sunday, September 14, 2008 1:32:02 AM(UTC)
You have a fuse in the wiring harness, just check per the schematic. Either that or a blown thermal protector internal to the motor.
Montana_Pete
#7 Posted : Sunday, September 14, 2008 10:44:15 AM(UTC)
Montana_Pete
LEDS on motor blinking 1 second constant on off. What does this indicate as to motor health?
libertyappl
#8 Posted : Sunday, September 14, 2008 8:34:09 PM(UTC)
libertyappl
I'm going to say it's the motor that's out.
Nat
ftmaster281
#9 Posted: : Wednesday, September 21, 2011 5:01:59 PM(UTC)
ftmaster281
i have tested the fuse link and it is fine and also tested the door magnet and that is working ok.
ftmaster281
#10 Posted : Wednesday, September 21, 2011 5:17:33 PM(UTC)
ftmaster281
how can i tell if my motor will not work even if the led light is on .
GE washer will fill and drain but no spin/agitate (Washer Repair)
by corndogg 7/1/2008 6:27:36 PM(UTC)
2 Pages12>
