AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE washer will fill and drain but no spin/agitate
I need some serious help with this new GE washer. GE washer will no longer spin or agitate. Will fill and drain ok. But no motor action.
#1 I checked inline motor fuse it looked ok. But direct wired it anyway :) #2 Motor LED flashes constantly 1sec on 1sec off
What sensor might no be letting the motor start?
What should I check next?
Washing backing up here in Montana :(
I can't pull up the model number you have posted, but start by checking the lid switch and the belt. and double check the model number please. Nat
http://products.geapplia...SE5240GWW&SITEID=GEAYes belt is perfect and lid switch is magnetic and makes a little clicking sound when I open and close it.. Machine is just over a year old.... Motor LED binks on / off every one second constant. Water fills and drains but it just won't activate the motor. Should I cut lid wires and connect to be sure?
Check the connections at the motor, and if you can test the motor. We had one of these about a month ago and it was the motor. I don't remember all the details of it will have to look it up. Nat
I don't know how to test the motor.
LED is blinking 1 sec on 1 sec off contant.
Do you have a hot wire pin out for this thing?
You have a fuse in the wiring harness, just check per the schematic. Either that or a blown thermal protector internal to the motor.
LEDS on motor blinking 1 second constant on off. What does this indicate as to motor health?
I'm going to say it's the motor that's out. Nat
i have tested the fuse link and it is fine and also tested the door magnet and that is working ok.
how can i tell if my motor will not work even if the led light is on .
Washer Repair
