Gene2446
#1 Posted : Wednesday, September 10, 2008 12:14:49 PM(UTC)
Gene2446
I would like to change the size of the ice cubes?
Is this possible? I find no buttons or knobs to turn to
change the size.
Thank you
Gene2446
libertyappl
#2 Posted : Wednesday, September 10, 2008 2:10:04 PM(UTC)
libertyappl
If you remove the plastic cover on the front of the icemaker there is a philips screw that you can turn to adjust the amount of water coming into the ice tray. Only turn in a tiny bit at a time
Nat
Gene2446
#3 Posted : Thursday, September 11, 2008 12:35:24 PM(UTC)
Gene2446
Nat:
Thank you Very Much
Gene2446
libertyappl
#4 Posted : Thursday, September 11, 2008 12:42:14 PM(UTC)
libertyappl
you're welcome hope that helps.
Nat
Gene2446
#5 Posted : Friday, September 12, 2008 10:00:38 AM(UTC)
Gene2446
Nat:
When I remove the cover to the ice maker I find to
recessed phillps head screws, one on the left of the
dial and one on the right. I tried turning both, but
it seems that they only hold the ice tray to the controls.
It didn't make any difference which screw I turned, it didn't change anything. Help Please!
Gene2446
libertyappl
#6 Posted : Friday, September 12, 2008 10:07:46 AM(UTC)
libertyappl
Do one of them have a + or - beside the screw hole? If not yours may not have the adjustment there. I will try to look up your model again.
Nat
libertyappl
#7 Posted : Friday, September 12, 2008 10:12:02 AM(UTC)
libertyappl
The pictures they show online aren't very good. Your model may not be adjustable. Do you see a part number on the IM, they use different ones.
Nat
libertyappl
#8 Posted : Friday, September 12, 2008 10:22:02 AM(UTC)
libertyappl
Gene,
I'm going to try to post a PDF file for your refrgerator. Which tell you how to adjust the water level for the ice (page 4-4). If it doesn't work send me an email and I will email it
Nat
File Attachment(s):
16010154.pdf (1,393kb) downloaded 12 time(s).
Gene2446
#9 Posted : Friday, September 12, 2008 12:07:32 PM(UTC)
Gene2446
Nat:
Thanks, a received the pdf file. The diagram looks just like my ice maker, maybe I can get the size
changed.....Thanks again
Gene2446
libertyappl
#10 Posted : Friday, September 12, 2008 12:29:30 PM(UTC)
libertyappl
You're welcome hope it works!
Nat
Guest (6)
