I would like to change the size of the ice cubes? Is this possible? I find no buttons or knobs to turn to change the size. Thank you Gene2446
If you remove the plastic cover on the front of the icemaker there is a philips screw that you can turn to adjust the amount of water coming into the ice tray. Only turn in a tiny bit at a time Nat
Nat:
Thank you Very Much
Gene2446
you're welcome hope that helps. Nat
Nat:
When I remove the cover to the ice maker I find to recessed phillps head screws, one on the left of the dial and one on the right. I tried turning both, but it seems that they only hold the ice tray to the controls. It didn't make any difference which screw I turned, it didn't change anything. Help Please! Gene2446
Do one of them have a + or - beside the screw hole? If not yours may not have the adjustment there. I will try to look up your model again. Nat
The pictures they show online aren't very good. Your model may not be adjustable. Do you see a part number on the IM, they use different ones. Nat
Gene, I'm going to try to post a PDF file for your refrgerator. Which tell you how to adjust the water level for the ice (page 4-4). If it doesn't work send me an email and I will email it Nat
Nat:
Thanks, a received the pdf file. The diagram looks just like my ice maker, maybe I can get the size changed.....Thanks again Gene2446
You're welcome hope it works! Nat
