re dishwasher
when i push the start resume button it flashes nothing else happens.
the door is firmly closed and the breaker is not tripped
THIS FORUM IS DEAD!!!!!!! |
when we initiate the diagnostic sequence by pushing normal wash heated dry normal wash heated dry, all the ligts on the control panel come on then they go out , then you can start the machine s wash cycle but it is an abbreviated cycle . When it is done the clean light flashes and it will not work again unless you innitiate the diagnostic sequence again Originally Posted by: denman
:confused: Originally Posted by: kevin melin  when we initiate the diagnostic sequence by pushing normal wash heated dry normal wash heated dry, all the ligts on the control panel come on then they go out , then you can start the machine s wash cycle but it is an abbreviated cycle . When it is done the clean light flashes and it will not work again unless you innitiate the diagnostic sequence again could it still be the thermal fuse after all this.:)
