km
kevin melin
#1 Posted : Saturday, January 22, 2011 10:25:25 AM(UTC)
kevin melin
re dishwasher
when i push the start resume button it flashes
nothing else happens.
the door is firmly closed and the breaker is not tripped
#2 Posted : Sunday, January 23, 2011 2:39:37 AM(UTC)
Replacement parts for KENMORE 66517052402 by Kenmore Elite | AppliancePartsPros.com
Could be the thermal fuse is blown.
It will be on/near the control board.
Remove it and check it with a meter, should be 0 ohms.
If blown be sure to use the new wiring harness that comes with the replacement fuse.
kevin melin
#3 Posted : Monday, January 24, 2011 5:24:48 AM(UTC)
kevin melin
when we initiate the diagnostic sequence by pushing normal wash heated dry normal wash heated dry, all the ligts on the control panel come on then they go out , then you can start the machine s wash cycle but it is an abbreviated cycle . When it is done the clean light flashes and it will not work again unless you innitiate the diagnostic sequence again
Originally Posted by: denman Go to Quoted Post
kevin melin
#4 Posted : Monday, January 24, 2011 5:27:22 AM(UTC)
kevin melin
:confused:
could it still be the thermal fuse after all this.:)
KMBS104ESS02 wont start. Some buttons unresponsive (Microwave Repair)
by Guest 7/10/2022 1:22:03 PM(UTC)
Ckmnu (Washer Repair)
by CKMNU 10/23/2011 9:03:31 AM(UTC)
rkmcprez (Washer Repair)
by rkmcprez 8/17/2011 8:08:36 AM(UTC)
JVM-1851BH06 GE Spackmaker xl 1800 (Microwave Repair)
by zahoorshah 12/10/2010 6:26:17 AM(UTC)
wszkm (Washer Repair)
by wszkm 10/16/2009 10:39:22 AM(UTC)
needparts for miele km326 g cooktop (Oven Repair (including Ranges and Cooktops))
by peter erb 5/17/2009 6:18:51 PM(UTC)
Whirlpool KM-27 dead, no power (Microwave Repair)
by gospog 5/7/2008 10:43:23 AM(UTC)
PAKMANs Water drip in the Frig (Refrigerator & Freezer Repair)
by PAKMAN 12/26/2007 5:00:58 PM(UTC)
