Smithjws4
#1 Posted : Sunday, January 23, 2011 9:47:30 AM(UTC)
Smithjws4
The dryer starts and runs. It does not heat or time out.
#2 Posted : Monday, January 24, 2011 2:01:42 AM(UTC)
Here is your wiring diagram, see the attachment.
If the timer does not advance in both auto and timed dry modes, odds are you have a power problem.
In timed dry the timer mpotor runs directly off the 240 volts through Timer Switch 0 WB/TM contacts. The heater also runs off of the 240 so if both are not working the first thing to check is the power,
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If it does advance in timed dry then the first thing to check would be the heating coil.
Should be about 10 to 12 ohms.
File Attachment(s):
11076732501.pdf (197kb) downloaded 37 time(s).
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
kenmore 70 series dryer is burning clothes (Dryer Repair)
by lindasomerville 3/15/2012 1:59:55 PM(UTC)
Kenmore 70 Series Dryer timer not working (Dryer Repair)
by bobbydc 2/17/2012 1:49:55 PM(UTC)
Kenmore 70 Series Dryer, timer does not stop dryer (Dryer Repair)
by rjoshuaw 11/29/2011 5:07:26 PM(UTC)
Kenmore 70 Series dryer timers (Dryer Repair)
by FoxCMK 2/21/2011 6:44:46 AM(UTC)
Kenmore 70 Series dryer stains clothes, takes over 90 minutes to fully dry (Dryer Repair)
by Peretz 10/11/2009 2:58:08 PM(UTC)
Kenmore 70 series dryer is slow to dry. (Dryer Repair)
by borger10 10/3/2009 7:36:24 AM(UTC)
Kenmore 70 series dryer repair help (Dryer Repair)
by qkhan525 9/6/2009 12:09:45 PM(UTC)
