2 Pages12>
MGL
#1 Posted : Thursday, September 11, 2008 9:55:56 AM(UTC)
MGL
The fresh food section was getting warmer and freezer was cool. So I thought the air circulation is not working. Cool air from freezer is not going to fresh food section. Also I saw freezer fan not rotating.
I opened the freezer back panel to check the fan. I saw the evaporator coil was clean with no frost. I closed the panel and set temperature to 5 (coldest). Next day I saw things started cooling and the fan in the freezer throwing air. Air circulation was normal.
The cooling lasted two days and again fresh food section was warm. I opened the back panel again thinking that defrost is not happening. But again I saw evaporator coil is clean with some frost. So I used air dryer and set cool air on the coil. Also I set temp to 5 (coldest).
Now I do not see anything cooling also the fan is not rotating.
Please let me know what could be the issue.
libertyappl
#2 Posted : Thursday, September 11, 2008 9:58:24 AM(UTC)
libertyappl
replace your fan evaporator motor and you should be good to go.
Nat
MGL
#3 Posted : Thursday, September 11, 2008 10:07:54 AM(UTC)
MGL
But the first time fan started working.
libertyappl
#4 Posted : Thursday, September 11, 2008 10:20:56 AM(UTC)
libertyappl
Sometimes they are sparatic then just quit. check the wire connects first though.
MGL
#5 Posted : Thursday, September 11, 2008 10:29:35 AM(UTC)
MGL
I just checked the freezer now and its not cooling.
So will changing the fan motor help ?
MGL
#6 Posted : Thursday, September 11, 2008 10:38:12 AM(UTC)
MGL
Please help.
MGL
#7 Posted : Thursday, September 11, 2008 11:10:49 AM(UTC)
MGL
libertyappl
#8 Posted : Thursday, September 11, 2008 12:14:25 PM(UTC)
libertyappl
Feel your compressor to see if it's very hot and running.
Nat
MGL
#9 Posted : Thursday, September 11, 2008 8:57:35 PM(UTC)
MGL
Nat,
Yes. Compressor was somewhat hot but not running.
Later I manually moved the defrost timer to start cooling cycle. After doing this the compressor started running and Freezer started cooling. But the freezer fan did not start at all.
So I think I need to change the fan motor. Also should I replace the defrost timer since freezer stops cooling and does not go to cooling cycle ?
libertyappl
#10 Posted : Friday, September 12, 2008 5:51:24 AM(UTC)
libertyappl
The defrost timer may be "stuck" not allowing the comprssor to kick back on.
Nat
Guest (12)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
2 Pages12>
