jhoium
#1 Posted : Saturday, September 29, 2007 8:51:16 AM(UTC)
jhoium
GE Electric oven does not shut off. Seems to heat to the proper temp when the knob ison, but when turned off it seems to get hotter and does nto shut off. I have to turn off the circuit breaker.
Admin / APP Team
#2 Posted : Saturday, September 29, 2007 10:42:58 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
JBP21 is not a complete model number. Could you post the complete number?
jhoium
#3 Posted : Sunday, September 30, 2007 10:43:11 AM(UTC)
jhoium
Model# JBP21BY2WH
Also, if I turn the oven on, it seems to heat to the correct temp, but when I turn the oven off, the temp increases. Not sure how hot it will get. I hit the breaker after it heated to about 450.
It's just the bottom burner too. Not the broiler.
Admin / APP Team
#4 Posted : Tuesday, October 2, 2007 12:32:26 PM(UTC)
Admin / APP Team
Groups:
Sounds like the bake relay on the control board is bad. The relay's part of the board and is not available separately. Replace the board and it should be back to normal.
- Replacement board for JBP21BY2WH
Gas Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by gj2001 3/1/2013 2:26:38 PM(UTC)
Oven will not shut off (Oven Repair (including Ranges and Cooktops))
by michael.visconti 8/24/2012 11:42:45 AM(UTC)
top oven will not shut off when temp is reached (Oven Repair (including Ranges and Cooktops))
by eldonmac 8/20/2012 2:24:05 PM(UTC)
by Trentkc 1/16/2011 12:18:11 PM(UTC)
Broil Element in Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by stebbs 10/11/2010 7:11:42 AM(UTC)
by bborgerding 7/26/2010 1:52:26 PM(UTC)
My oven will not shut off (Oven Repair (including Ranges and Cooktops))
by brandielee28 11/27/2009 11:24:16 AM(UTC)
by KayHicks 9/22/2009 10:39:33 AM(UTC)
by michelleedwards 5/29/2009 5:23:10 AM(UTC)
Lower oven will not shut off (Oven Repair (including Ranges and Cooktops))
by Rick Stacy 4/12/2009 7:04:35 AM(UTC)
