jhoium
#1 Posted : 17 years ago
jhoium
GE Electric oven does not shut off. Seems to heat to the proper temp when the knob ison, but when turned off it seems to get hotter and does nto shut off. I have to turn off the circuit breaker.
Admin / APP Team
#2 Posted : 17 years ago
Admin / APP Team
Rank: Administration
JBP21 is not a complete model number. Could you post the complete number?
jhoium
#3 Posted : 17 years ago
jhoium
Model# JBP21BY2WH
Also, if I turn the oven on, it seems to heat to the correct temp, but when I turn the oven off, the temp increases. Not sure how hot it will get. I hit the breaker after it heated to about 450.
It's just the bottom burner too. Not the broiler.
Admin / APP Team
#4 Posted : 17 years ago
Admin / APP Team
Sounds like the bake relay on the control board is bad. The relay's part of the board and is not available separately. Replace the board and it should be back to normal.
- Replacement board for JBP21BY2WH
Gas Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by gj2001 12 years ago
Oven will not shut off (Oven Repair (including Ranges and Cooktops))
by michael.visconti 13 years ago
top oven will not shut off when temp is reached (Oven Repair (including Ranges and Cooktops))
by eldonmac 13 years ago
by Trentkc 14 years ago
Broil Element in Oven Will Not Shut Off (Oven Repair (including Ranges and Cooktops))
by stebbs 14 years ago
by bborgerding 15 years ago
My oven will not shut off (Oven Repair (including Ranges and Cooktops))
by brandielee28 15 years ago
by KayHicks 15 years ago
by michelleedwards 16 years ago
Lower oven will not shut off (Oven Repair (including Ranges and Cooktops))
by Rick Stacy 16 years ago
