tractor1
#1 Posted : Wednesday, September 10, 2008 6:51:00 PM(UTC)
tractor1
I Saw A Yellow Flash Under The Ceramic Cooktop And The One Element Had Burned Out. I Replaced The Left Front Element And It Does Not Work. The Element On Light Does Not Light Up When That Burner Is Turned On And The Burner Does Not Heat Up. All The Other Burners And Oven Works And Light Up The Indicater Lights. Could This Be A Defective New Burner Or Could Anything Else Be Wrong After The Element Burned Out.
libertyappl
#2 Posted : Wednesday, September 10, 2008 7:23:19 PM(UTC)
libertyappl
Check the wire connectors sounds like something is crossed.
Nat
tractor1
#3 Posted : Wednesday, September 10, 2008 7:43:38 PM(UTC)
tractor1
I Drew Diagram And Color Of Wires Before Unhooking Wires And New Element Was Hooked Up Same Way As Old One.
ApplianceJunk
#4 Posted : Wednesday, September 10, 2008 8:43:22 PM(UTC)
ApplianceJunk
When the old burner when out it could have damaged the switch for that burner too.
ApplianceJunk
#5 Posted : Wednesday, September 10, 2008 8:45:12 PM(UTC)
ApplianceJunk
If you have a volt meter you could check to see if you have votage out of the switch to the burner.
tractor1
#6 Posted : Thursday, September 11, 2008 4:24:58 PM(UTC)
tractor1
There is 125v on black wire going to the burner that does not work and the same voltage going to the other burners that do work.
#7 Posted : Friday, September 12, 2008 1:39:06 PM(UTC)
There is suppose to be 240VAC, consists of two legs (wires) 120VAC each to power up the heating element. If one of these legs is missing then the heating element would never work and the problem, as ApplianceJunk said, is a bad burner switch.
If you can post the wiring diagram it might help to provide more accurate advise.
kitchenAid surface element (Oven Repair (including Ranges and Cooktops))
by webs 11/19/2023 7:40:50 AM(UTC)
Surface element will not fully heat (Oven Repair (including Ranges and Cooktops))
by meyer077 10/28/2019 7:35:11 AM(UTC)
Surface Element Switch Amps (Oven Repair (including Ranges and Cooktops))
by splash13 6/21/2017 1:14:26 PM(UTC)
Surface elements locked out (Oven Repair (including Ranges and Cooktops))
by Jaykruz 3/21/2014 2:37:00 PM(UTC)
Dead surface elements (Oven Repair (including Ranges and Cooktops))
by glenmar 8/1/2013 3:56:07 PM(UTC)
2 surface elements always on (Oven Repair (including Ranges and Cooktops))
by wiluspyder 8/21/2012 3:12:21 PM(UTC)
Range surface elements come on without being turned on (Oven Repair (including Ranges and Cooktops))
by wilard428 4/24/2011 12:32:37 PM(UTC)
Surface Element Removal on Whirlpool Cooktop (Oven Repair (including Ranges and Cooktops))
by trot1107 4/6/2011 7:07:04 AM(UTC)
Surface Element 6" for Cooktop (Oven Repair (including Ranges and Cooktops))
by GaryET 10/9/2009 8:38:09 AM(UTC)
Surface element does not heat (Oven Repair (including Ranges and Cooktops))
by lonepalm 6/21/2009 9:30:22 AM(UTC)
FRIGIDAIRE Surface element (Oven Repair (including Ranges and Cooktops))
by jrc140 5/20/2009 1:31:08 PM(UTC)
surface elements on glass top (Oven Repair (including Ranges and Cooktops))
by douglo 12/21/2008 9:07:42 AM(UTC)
Surface element block rewiring (Oven Repair (including Ranges and Cooktops))
by teresa1 10/27/2008 3:07:35 PM(UTC)
replace surface element (Oven Repair (including Ranges and Cooktops))
by gaitherjohn@hotmail.com 1/31/2008 8:46:31 AM(UTC)
Surface Element Repair (Oven Repair (including Ranges and Cooktops))
by lan68 1/30/2008 4:26:49 AM(UTC)
