phish_phinder
#1 Posted : Monday, January 17, 2011 7:33:21 AM(UTC)
phish_phinder
Washer starts to fill and stops after 5 sec onds or so. Press the button in and out and stars back for 5 seconds, once filled it works fine. What is the problem?
magician59
#2 Posted : Monday, January 17, 2011 7:50:06 AM(UTC)
magician59
Does it act the same in all the possible wash/rinse combinations you can select?
phish_phinder
#3 Posted : Monday, January 17, 2011 8:02:28 AM(UTC)
phish_phinder
Yes, normal , gentle , and perm. press all do the same thing.
magician59
#4 Posted : Monday, January 17, 2011 8:21:23 AM(UTC)
magician59
I would suspect either ayour temperature selector switch, or a bad timer.
phish_phinder
#5 Posted : Monday, January 17, 2011 8:26:42 AM(UTC)
phish_phinder
I only use cold cold.... I do not have hot water supply. If I switch setting you say it might work?
magician59
#6 Posted : Monday, January 17, 2011 8:33:57 AM(UTC)
magician59
If you switch the setting, and it does the same thing, I would suspect the timer.
AFTERTHOUGHT:
Check to see if the air tube from the water lever switch is clogged, kinked, or otherwise restricted. This switch really controlls the voltage to the water inlet valve; When the switch is satisfied (by pressure related to your fill level selected), the voltage to the valve is interrupted, and the timer then takes over the operation. If there is a restriction in the tube or the air dome attached to the tub (this can be a lint clog), the switch can be tricked into "thinking" there's water in the tub.
Tell us what you find.
phish_phinder
#7 Posted : Monday, January 17, 2011 10:22:06 AM(UTC)
phish_phinder
Someone switched it to hot cold not knowing we didnt have hot water , problem solved, cant believe i overlooked where the setting was assuming i always keep it on cold cold, thanks for your help and glad I found this forum.
