With Your Help Removed Heat Element,found It Was Good But Thermal Fuse Open,replaced.work 5 Days, Fuse Open Again. No Arking Or Loose Terminals.????? Any Advice.
These thermal fuses are very senitive to partial restrictions and clogs in the ventilation system. Make sure the vent is clear, from the inside of your dryer, to the outside of the house.
