dragonseker
#1 Posted : Monday, January 10, 2011 10:02:54 AM(UTC)
dragonseker
I have a 20 yr. old Maytag gas dryer that on initial start up, it has a rumbling sound as described by others in your forum. But mine only rumbles on the initial start up and goes away when it reaches it peak RPM's. Everything else works fine.
MPB
kayakcrzy
#2 Posted : Monday, January 10, 2011 2:33:46 PM(UTC)
kayakcrzy
Replace the blower wheel!!! If you turn on the dryer for a minute, and then open the door and the drum will stop but the rumble will still go for a few seconds, it will be the blower wheel. Or, if you want to take the front off, and then you can get to the blower wheel, and spin it. If it free spins without moving the drum, there you have it. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
dragonseker
#3 Posted : Tuesday, January 11, 2011 9:02:02 AM(UTC)
dragonseker
I don't think so Tim, My sound is a rumbling sound and goes away after a few seconds. If it was coming from the blower wheel, which is plastic, it would make a scraping sound as it would be off track and would continue making a sound, whereas my sound is a Rumble starts on initial start up, and stops after a few seconds as the dryer is still running.
kayakcrzy
#4 Posted : Tuesday, January 11, 2011 9:15:54 AM(UTC)
kayakcrzy
Did you look at it??? Or, are you speculating?? Tom
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
