JJM63
#1 Posted : Saturday, January 8, 2011 12:56:39 PM(UTC)
JJM63
I have a Whirlpool top load washer that has been functioning great for the years I have owned it. However, for just over a week, there has been a moldy smell emanating from it. All drains are working well. The tub has been washed with Lysol but still to no avail. When I looked underneath the machine I noticed there was a white,plastic, slightly see thru "tub" attached to the bottom of the metal tub. It looks as if there is some sort of soap or scum buildup in this plastic tub. Could this be what is causing this moldy smell? If so, will the Affresh work on top load washers? Thank sincerely in advance for your help.
Best Regards,
Jay
#2 Posted : Sunday, January 9, 2011 1:29:26 AM(UTC)
A model number may help others help you.
You could try running a cycle with bleach.
Affresh may work, you will not know till you give it a try.
Whirlpool top load washer Model # WTW58ESVW quit working (Washer Repair)
by chuck gibson 3/12/2021 4:37:30 PM(UTC)
Help needed - Whirlpool top load washer (Washer Repair)
by lediaz 1/18/2019 8:18:13 AM(UTC)
Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves (Washer Repair)
by Girliemom21 7/18/2017 5:57:17 AM(UTC)
Whirlpool top load washer out of balance (Washer Repair)
by gvanzant1 12/3/2016 12:10:33 PM(UTC)
Whirlpool top load washer agitate but intermittent when spin (Washer Repair)
by phuong31 10/16/2015 7:56:27 AM(UTC)
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
whirlpool top load washer (Washer Repair)
by hvff0572 11/17/2013 12:43:06 PM(UTC)
Whirlpool Top load Washer clicks loudly in agitate mode and spin (Washer Repair)
by ggutshall87 10/14/2013 3:21:05 PM(UTC)
Whirlpool Top Load Washer (Washer Repair)
by stevesims 10/29/2012 10:06:36 AM(UTC)
whirlpool top load washer knocks during spin (Washer Repair)
by Jim O 9/24/2012 6:58:09 PM(UTC)
Whirlpool Top Load Washer no water (Washer Repair)
by al-lawn 7/27/2012 2:02:32 PM(UTC)
by tfontana43 6/18/2012 11:34:29 AM(UTC)
whirlpool top load washer won't spin. replaced coupler and clutch (Washer Repair)
by kodiakmook 1/22/2012 7:17:55 PM(UTC)
Whirlpool top load washer sqeal on spin UP (Washer Repair)
by squealer 6/25/2011 8:12:27 PM(UTC)
Whirlpool Top Load Washer not balanced (Washer Repair)
by Jerry Terkelson 3/25/2011 12:25:52 PM(UTC)
