Put In new Bake element (old one broke and burnt out) first heat cycle it took 40mins to pre heat to 400 turned off oven for a few hours tried again at 350 took 40 min again any suggestions.
Originally Posted by: 1lions  Put In new Bake element (old one broke and burnt out) first heat cycle it took 40mins to pre heat to 400 turned off oven for a few hours tried again at 350 took 40 min again any suggestions. 1Lions, Does the broil element work properly ? You may have a damaged or shorted wire in the cabinet back wall wiring harness. Do you have a multi meter, so you can check to see if you have 220 VAC. across the element terminals in a bake cycle ? That's where I'd look or test first. Good Luck, :) :) :)
