7 Pages«<4567>
boxpin
#51 Posted : Sunday, December 12, 2010 7:14:33 PM(UTC)
boxpin
So I have followed the advice on this forum and replaced the heater coil. The sad part is that I checked the two coils with an ohm meter and the both are identical meaning it wasnt broken. :-(
I just decided to put the new one in but sadly and expected I am still freezing up. Whats next? thermistor?
Does anyone know where I can view a SERVICE manual? (Not the users guide. I have found that a couple times searching.)
I have caught wind that there might be the ability to tell the fridge to run a defrost cycle....is this true and how?
Samsung RS2577BB
#52 Posted : Monday, December 13, 2010 12:58:52 AM(UTC)
boxpin
Here is the breakdown
Replacement parts for Samsung RS2577BB REF - SXS | AppliancePartsPros.com
This should help force a defrost
SAM0058 Samsung Sidy-By-Side Refrigerator Service Manual - ApplianceDigest.com
You may have to join the site to download the file but it is free and a good site to belong to for a DIYer
boxpin
#53 Posted : Monday, December 13, 2010 7:58:26 PM(UTC)
boxpin
WOW THAT HELPED!!!!
The service manual answered all my questions. I was able to put the fridge into defrost mode and it thawed. It also gave me the code saying the Thermistor was giving a wrong reading. Parts are ordered. Nice!
ddagsyn
#54 Posted : Tuesday, January 4, 2011 5:42:42 PM(UTC)
ddagsyn
Denman,
Do you have the repair manual for the Samsung RS2630. If so can you please post.
thanks
boxpin
#55 Posted : Tuesday, January 4, 2011 6:18:41 PM(UTC)
boxpin
Thermister has fixed the fridge. Nice cold milk and an Oreo...what could be better.
#56 Posted : Wednesday, January 5, 2011 1:43:45 AM(UTC)
[COLOR="Blue"]ddagsyn[/COLOR]
Sorry but I do not have it.
Perhaps open your own thread using "Post New Topic" at the top of this section and someone else may have it.
ddagsyn
#57 Posted : Thursday, January 6, 2011 4:26:14 AM(UTC)
ddagsyn
http://www.servicematters.com/maytag...cs/SAM0096.pdf
The above is the service manual I am looking for. The link is dead hopefully some one has a copy. thanks
pyro-1955
#58 Posted : Monday, February 28, 2011 8:57:04 AM(UTC)
pyro-1955
Originally Posted by: raventor Go to Quoted Post
I have the EXACT situation as you, have you had any luck figuring this out? i have already spent over 400 for repairs that didn't work
I also had the exact same problem. I purchased the Evaporator Coil / Defroster unit, as that is the only way they sell it. I defrosted the Refridgerator again with the hair dryer, then I replaced Both the Part that clamps onto the coil where it comes into the refridgerator compartment, and the one that goes along the side of the Evaporator coil . Defroster coil. I also carefully removed the existing defroster coil from the existing evaporator, and did the same with the New one. I then installed the New Defroster Coil onto the existing Evaporator coil, eliminating the need for removing the coolant and cutting coils, soldering, re-charging the compressor etc... It's working like a champ again. The part was around $75.00 delivered, but it's fixed, and I didn't have to pay Hundreds to get it fixed.
I did notice that when I initially re-started the refridgerator after installing the new parts, it came on, with the Error Code #3, however, once the refridgerator got up to or should I say down to normal working temperatures, I can now Unplug the refridgerator, then plug it back in, and it comes back on without any need to press and hold the Two buttons on the control panel, apparently it needs to register a normal setting before it can operate on it's own? I don't know, but all is good. This is the best fix I could find. Someone should Make this a default fix for these refridgerators.
rudeone43
#59 Posted : Thursday, May 5, 2011 1:47:57 PM(UTC)
rudeone43
Originally Posted by: denman Go to Quoted Post
Here is another service manual which looks more relevant
http://www.servicematters.com/m...library/docs/SAM0059.pdf
Your first link looks like the tube with the wires coming out of it is the defrost heater. Could not find a spec for it but is probably around 30 ohms.
The manual does show a thermal fuse in the evap area. This should be 0 ohms.
Also shows a thermistor, the resistance should change with temperature, see the table in the manual.
You will need a meter.
If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
woodchuckie
Hopefully the heater is OK. I also would be looking at a jiggery pokery if it was blown. Perhaps a length of pipe heating cable would work here depending on the wattage.
Would like to follow your lead on this but having trouble removing the panel any help would be greatly appreciated have melted ice and removed screws pulled the bottom out about half way up and then cracked a piece. any tricks are just keep working it back and forth?
oltunde
#60 Posted : Friday, October 7, 2011 5:10:05 PM(UTC)
oltunde
Originally Posted by: woodchuckie Go to Quoted Post
I have heard of that before. If it was mine and it went bad(which we don't know in this case yet) I would get a heater and rig it up with another one and place it like regular manufacturers do.
God you are my angel, I have this problem and it cost me about 400 to replce the unit. do you know of any heater I can buy and RIG it in:confused:
The resistance of the heater in the evaporator assembly is 103 ohms, 140 watts, and 120 volts AC.
many many thanks
Olga
Guest (10)
7 Pages«<4567>
