jotto
#1 Posted : Monday, January 3, 2011 10:55:27 AM(UTC)
jotto
Dryer Is Not Getting Hot Only Cold Air Being Exhausted Through Vent. Checked Vent And Is Not Clogged. Please Help
Joe / APP Team
#2 Posted : Tuesday, January 4, 2011 10:50:44 AM(UTC)
Joe / APP Team
Jotto,
This should be a gas dryer(heat source).
Have you removed the 1x1 plastic cover in the front panel and observed the ignition procedure ?
You do have gas supplied to the unit ?
When you remove the inspection cover, and look inside, you should see:
An orange glow,from the glowbar igniter,
In a few seconds, you should hear a click, and the glow bar igniter should start to fade.
At the same time the igniter starts to fade, you should be able to see the burner flame ignite,
*** Make sure a temperature selection is made and the timer dial is in a heat mode ( I usually set the dial on timed dry, at the 30 minute mark).***
Let us know what you observe, and we can get you on the correct path to repair your dryer.
Thanks,
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
