jmgaley
#1 Posted : Tuesday, September 2, 2008 7:06:51 AM(UTC)
jmgaley
Pulley, motor (w/set screw)
Part Number: AP3988722
made by MAYTAG
Does this pulley screw onto the shaft or slip on and lock down with the set screw?
#2 Posted : Tuesday, September 2, 2008 12:45:19 PM(UTC)
It slips on the shaft and tends to stick. The last one I pulled off the bad motor by putting the other end of the motor in a bench vice and loosened it with a pipe wrench. This works even if the set screw is stuck, just breaks it free.
Maytag Dryer Motor Pulley and Belt Restrainer problem (Dryer Repair)
by PHL 5/27/2015 10:46:48 PM(UTC)
