207 Pages«<1112131415>»
ktkhill
#121 Posted : Sunday, August 17, 2008 4:46:02 PM(UTC)
ktkhill
GE Arctica PSS26S GRD SS
I'm having a problem with my refigerator and freezer warming up. I have unplugged it and replugged it in. The temp would then go down but now its back up again. Current temp freezer 13 refrig 42. Help?
abadfish66
#122 Posted : Sunday, August 17, 2008 10:39:27 PM(UTC)
abadfish66
KTK. Please post serial#. Also check if the freezer fan is running, also is the center divider of the box hot to the touch, if it is, yake off the back access cover and veriify if the condensor fan is running, or if you have a very dirty condensor.
GLL
#123 Posted : Thursday, August 28, 2008 6:24:10 PM(UTC)
GLL
I have the same issue. I have a GE (Ser# LD308303; Model# GTS22UBMBRCC). The freezer is very cold and warm in the frig.
I removed the back panel and yes there was ice all over the evp coil. After reading this post, I decided to replace the defrost heater and thermostat.
I had the frig on for 24 hours and the frig is still not cold. The evp coil has ice on it.
I can't seem to locate the defrost timer also. Not sure if this model has a defrost timer.
Now, I'm starting to think that I have a bad board.
Can anyone confirm? Any help would be great.
Thanks all
This is an awesome board.
GLL
edgar
#124 Posted : Friday, August 29, 2008 7:41:58 PM(UTC)
edgar
check evap & condenser fan ok,no air blockage but i do not have enough cold air coming out to the ref side . Is the evap fan a multi speed maybe it is on the low speed.thanks
#125 Posted : Tuesday, September 2, 2008 12:46:28 PM(UTC)
Edgar,
What is the complete model number of the refrigerator?
#126 Posted : Tuesday, September 2, 2008 1:13:43 PM(UTC)
GLL,
Does the fan inside the freezer work properly?
devsam2@yahoo.com
#127 Posted : Wednesday, September 3, 2008 5:22:46 AM(UTC)
devsam2@yahoo.com
I have a GE Model# GTS22WCMARWW.
The freezer is freezing but the frig is not cold. I replaced the Evaporator Motor and it does not turn on. I had the mother board replaced about 4 years ago.
#128 Posted : Wednesday, September 3, 2008 1:04:12 PM(UTC)
devsam2@yahoo.com,
In such GE refrigerators when the evaporator fan goes bad it causing damage to the main control board. Both of these parts should be replaced together.
Here are the break down diagrams for the GE refrigerator Model GTS22WCMARWW
devsam2@yahoo.com
#129 Posted : Wednesday, September 3, 2008 4:37:19 PM(UTC)
devsam2@yahoo.com
...for quick response!
I just placed an order for the board.
Johnnie
Is there anything I need to know when replacing it?
#130 Posted : Wednesday, September 3, 2008 4:48:00 PM(UTC)
Not much. Keep us posted.
Guest (28)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
