Cold water level just keeps fill. I have to manually turn the water off. Hot water is ok. Does anyone know how to fix this problem? Thanks
Does it fill when the washer is turned off? If so you need a new water valve.
yes it fills when washer is turned off and unpluged. How do I fix this? I do not have the manual for the machine.
Get me the model# and I can help
i think this is it WWA5600
Thanks, Found a paper that has this # on it 175D1550G047 I think it is the schematic for the washer. It give a Replacement part # for the inlet valve as WH13X62. Would this be what I am looking for?
yep, the WH13x62 has changed to a WH13x81
Thank you for all your help. Will go get the part and let you know if it fixed. Thanks again.
Hey abadfish66, Got a 'blond' question. Is the valve the thing that the hot and cold water attach to? lol Where would I find one of these valve? Would home depot have them?
