2 Pages12>
busygrandma
#1 Posted : Friday, August 29, 2008 8:01:41 AM(UTC)
busygrandma
Cold water level just keeps fill. I have to manually turn the water off. Hot water is ok. Does anyone know how to fix this problem? Thanks
abadfish66
#2 Posted : Friday, August 29, 2008 8:46:43 AM(UTC)
abadfish66
Does it fill when the washer is turned off? If so you need a new water valve.
busygrandma
#3 Posted : Friday, August 29, 2008 9:23:45 AM(UTC)
busygrandma
yes it fills when washer is turned off and unpluged. How do I fix this? I do not have the manual for the machine.
abadfish66
#4 Posted : Friday, August 29, 2008 9:49:46 AM(UTC)
abadfish66
Get me the model# and I can help
busygrandma
#5 Posted : Friday, August 29, 2008 10:55:01 AM(UTC)
busygrandma
i think this is it WWA5600
abadfish66
#6 Posted : Friday, August 29, 2008 11:21:01 AM(UTC)
abadfish66
Here is the part#...Part Details - GE Water inlet valve, with insert, part number: WH13X81
You need to remove the back panel of the washer, and the valve is on the right side. Take the hoses off and unscrew the valve and put the new one in.
busygrandma
#7 Posted : Friday, August 29, 2008 11:35:51 AM(UTC)
busygrandma
Thanks, Found a paper that has this # on it 175D1550G047 I think it is the schematic for the washer. It give a Replacement part # for the inlet valve as WH13X62. Would this be what I am looking for?
abadfish66
#8 Posted : Friday, August 29, 2008 11:49:54 AM(UTC)
abadfish66
yep, the WH13x62 has changed to a WH13x81
busygrandma
#9 Posted : Friday, August 29, 2008 12:21:59 PM(UTC)
busygrandma
Thank you for all your help. Will go get the part and let you know if it fixed.
Thanks again.
busygrandma
#10 Posted : Friday, August 29, 2008 12:48:35 PM(UTC)
busygrandma
Hey abadfish66, Got a 'blond' question. Is the valve the thing that the hot and cold water attach to? lol Where would I find one of these valve? Would home depot have them?
2 Pages12>
