Jacuelyn
#1 Posted : 14 years ago
Jacuelyn
Hi I have a Whirlpool, Imperial Series that I purchased in '05. The washer will agitate and drain but it will not spin. It sounds as though it is working but there is no movement.:confused:
magician59
#2 Posted : 14 years ago
magician59
Sounds like you need a motor coupling.
Part number: AP3963893
Jacuelyn
#3 Posted : 14 years ago
Jacuelyn
Motor Coupling is good:confused:
magician59
#4 Posted : 14 years ago
magician59
Remove the cabinet, jumper the lid switch and put it into a spin cycle. Look at the clutch housing (#5 in this drawing). If it is spinning, the trouble lies outside the gearcase. If it isn't, the trouble is inside the gearcase.
Brake, clutch, gearcase, motor and pump parts replacement parts for WHIRLPOOL LSN1000PQ0 AUTOMATIC WASHER | AppliancePartsPros.com
genewaco
#5 Posted : 14 years ago
genewaco
i have a whirlpool washer wont spin model is mav6260aww what i do
genewaco
#6 Posted : 14 years ago
genewaco
what does a water level switch look like
