Jacuelyn
#1 Posted : Monday, December 20, 2010 9:12:02 AM(UTC)
Jacuelyn
Hi I have a Whirlpool, Imperial Series that I purchased in '05. The washer will agitate and drain but it will not spin. It sounds as though it is working but there is no movement.:confused:
magician59
#2 Posted : Monday, December 20, 2010 10:52:57 AM(UTC)
magician59
Sounds like you need a motor coupling.
Part number: AP3963893
Jacuelyn
#3 Posted : Monday, December 20, 2010 6:11:01 PM(UTC)
Jacuelyn
Motor Coupling is good:confused:
magician59
#4 Posted : Tuesday, December 21, 2010 4:59:07 AM(UTC)
magician59
Remove the cabinet, jumper the lid switch and put it into a spin cycle. Look at the clutch housing (#5 in this drawing). If it is spinning, the trouble lies outside the gearcase. If it isn't, the trouble is inside the gearcase.
Brake, clutch, gearcase, motor and pump parts replacement parts for WHIRLPOOL LSN1000PQ0 AUTOMATIC WASHER | AppliancePartsPros.com
genewaco
#5 Posted : Monday, December 27, 2010 3:55:49 PM(UTC)
genewaco
i have a whirlpool washer wont spin model is mav6260aww what i do
genewaco
#6 Posted : Monday, December 27, 2010 3:57:12 PM(UTC)
genewaco
what does a water level switch look like
Guest (5)
