chatham1
#1 Posted : Wednesday, August 27, 2008 4:11:49 PM(UTC)
chatham1
My front load washer will not spin (all other functions seem to work) so I bought a new belt! ITS NOT THE BELT!! So what next? Ron
#2 Posted : Wednesday, August 27, 2008 6:34:48 PM(UTC)
It could be the motor control board or the motor itself. Remove the bottom panel and locate an envelope with the tech sheets. Perform the troubleshooting according to instructions from the tech sheets.
Here are the break down diagrams for the Frigidaire washer Model GTF1040AS0
libertyappl
#3 Posted : Wednesday, August 27, 2008 6:38:28 PM(UTC)
libertyappl
If you can read the tech sheet it will help you sounds like it could be a motor or motor control issue. When it comes to most front load washers and problems like yours I recommend havine a certified tech look at it.
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
by Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
