PeteME
#1 Posted : Thursday, September 27, 2007 10:01:48 AM(UTC)
PeteME
I need to replace the plastic control housing and must take off the plastic control cover to do so. How does the control panel come off? How do I remove it (is it screwed, snapped, etc). No screws are evident, but may be hidden?
#2 Posted : Wednesday, October 3, 2007 6:55:46 PM(UTC)
Hi PeteME
I'm assuming you already removed the fascia panel .
Remove one screw on each side of the inner door panel holding the controls bracket and pull it out as far as wires go. The housing for the control module has three tabs on the bottom. Push them up and in and push the housing inward.
Now you can replace the housing.
Good luck.
LG LFXS28968S /00 control panel removal (Refrigerator & Freezer Repair)
by Guest 11/15/2023 5:36:56 PM(UTC)
control panel removal (Washer Repair)
by jwdyer2445 7/30/2012 10:17:57 PM(UTC)
Kitchenaid KSRG25FKSS16 Ice dispenser control panel removal (Refrigerator & Freezer Repair)
by gbooth 12/29/2011 3:14:20 PM(UTC)
control panel removal (Dryer Repair)
by Pauly H 10/25/2010 7:21:04 AM(UTC)
whirlpool double oven control panel removal (Oven Repair (including Ranges and Cooktops))
by Glrbird 5/5/2010 11:07:44 AM(UTC)
Keypad / control panel removal & replacement (Oven Repair (including Ranges and Cooktops))
by Fireweed 8/26/2009 7:53:57 AM(UTC)
DMO24 Control Panel Removal (Microwave Repair)
by reh 3/20/2009 5:25:26 AM(UTC)
Electric oven control panel removal (Oven Repair (including Ranges and Cooktops))
by stpedson 3/14/2009 9:11:46 AM(UTC)
Control Panel Removal (Refrigerator & Freezer Repair)
by Sonettech 11/16/2008 8:03:02 PM(UTC)
by Forastiero 11/5/2008 7:49:42 AM(UTC)
by bjthedj 10/27/2008 8:11:51 AM(UTC)
