How do I get the control panel to swing up on this Kenmore Washer 11026912691. I am having a "no hot water" problem and trying to get to the wiring harness and switches to check out whether it is the temp switch or the solenoid on the water inlet valve. Thanks
The following is the video instructions. I hope it will help.
[youtube]OlAFQnkapLM&rel=1[/youtube] Gene.
