ckmarie2
#1 Posted : Friday, August 22, 2008 5:22:08 PM(UTC)
ckmarie2
We've checked everything from the pinch valve supply to the water valve for deposits that might restrict flow. Every thing is clear including the screen at the water valve. The ice maker only makes four cubes at a time. The icetray does not fill up completely. What else should we check? The cold water dispenser in the door works OK.
libertyappl
#2 Posted : Friday, August 22, 2008 6:57:14 PM(UTC)
libertyappl
I'd say one side of the valve is out (part #AP2110670) you can switch the wires on the water valve then push the water dispenser button to see if you get water in your ice maker.
Nat
ckmarie2
#3 Posted : Sunday, August 24, 2008 8:38:43 PM(UTC)
ckmarie2
OK, I couldn't get the wires to come apart without fear of bfeaking something, so I switched the water lines. Now we can fill the ice maker with water but whe the ice maker switch asks for H2O it comes out in the door. There is less than 1/2 cup of H2O that comes out. So the valve seems to be working but not very well. Is there any adjustment on the water valve? Or should I just replace it?
libertyappl
#4 Posted : Sunday, August 24, 2008 8:53:27 PM(UTC)
libertyappl
Ok, take eight cubes and melt them down and see about how much water you are supposed to be getting to make a full tray. If memory serves 4 to 6 oz is about right. I'm not looking at your model right now but there might be an adjustment under the front cover on the icemaker itself.
ckmarie2
#5 Posted : Wednesday, August 27, 2008 4:09:07 PM(UTC)
ckmarie2
Well we melted the cubes as specified and came up short. The ice maker is still only filling up four cubes. There doesn't seem to be any adjustment on the ice maker itself. Any other suggestions?
libertyappl
#6 Posted : Wednesday, August 27, 2008 5:41:21 PM(UTC)
libertyappl
Does the water dispensser in the door fill up quickly as it should or is it slow?
libertyappl
#7 Posted : Wednesday, August 27, 2008 5:51:19 PM(UTC)
libertyappl
Ok, if you remove the square outer cover on the icemaker the adjustment is a screw inside a slot, above the gear a little to the right, it's a phillips screw turn that toward the plus sign a little at a time. Also make sure that the fill tube isn't frozen a little
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
