jerman
#1 Posted : Tuesday, September 25, 2007 10:10:10 PM(UTC)
jerman
maytag washer serial number 16846195ax : problem water does fill the washer on the timer fill cycle.Replaced water valve hot / cold.Had no effect on washer.Checked voltage across hot and cold solenoid valve.Could not detect voltage at solenoid valve unless using washer body used as ground.Detected approximately 100-108 volts at the hot and cold water solenoid valve.No ground at solenoid valve that i could see.It appears the neutral side is not completing the circuit when testing across the solenoid connectors ie no voltage reading.
Noticed the washer pumps out on the final rinse cycle and the agitator is working on that cycle.Otherwise no water filling the tub on the first cycle.
#2 Posted : Wednesday, September 26, 2007 1:09:53 AM(UTC)
The power ground wire is daisy chained at different places in the washer, you will need to ohm the connections starting at the power cord and ending at the solenoid.
jerman
#3 Posted : Wednesday, September 26, 2007 6:55:42 PM(UTC)
jerman
Thanks for the info will check the neutral from the power supply to the solenoid.Could the timer have a short on the neutral side and that is why i am not getting 120 volts at the solenoid cross connectors.The hot side of the timer is sending 120 volts while the timer is on and the timer is rotated through the wash cycle ie continuous voltage to the solenoid valve.Is this a timer problem.
#4 Posted : Thursday, September 27, 2007 1:06:57 AM(UTC)
Timer never switches power ground.
jerman
#5 Posted : Friday, October 12, 2007 9:14:56 PM(UTC)
jerman
How to remove the door switch.Removed screw between washer and dryer cabinet.How to continue
jerman
#6 Posted : Friday, October 12, 2007 9:17:00 PM(UTC)
jerman
maytag washer lsg7806aae How to remove the door switch?
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
