I also see that my model number does not come up. It gives me this model number as the closest match WJRE5500G0WW .
Mine is WJRE555OHOWW. Are they all the same parts between the two models?
I would like to order up a motor and get the wife all squared away this week. She starting to get a little restless without having a machine all week.
I am almost sure the parts will be the same but you may want to call to be sure. All that part of the model number means is what year the washer was made.
Do either of you fine young gentlemen happen to have a schematic to the timer board? It does have three 12vdc relays on it, and they can be replaced easily enough if one has the experience. Now the surface mounted stuff is another matter entirely. As is the software.Thanks!:)
Originally Posted by: jp-nelsen@texband.net  Do either of you fine young gentlemen happen to have a schematic to the timer board? It does have three 12vdc relays on it, and they can be replaced easily enough if one has the experience. Now the surface mounted stuff is another matter entirely. As is the software.Thanks!:) GE doesn’t provide us with that type of information.
